Outrunner motor comparisons ID's
BC, CANADA
New to electrics and need some help.The many confusing numbers asigned to the electric motors is frustrating.Is there are chart where one can compare manufactures?Common numbers from E Flight like 370's anf 450's 480 etc.
Then Hacker has some other numbers..and so on.
The Ulrafly motor Ultrafly B/12/10 would be comparable to which motor in the E flight line up? (Both outrunners)
One attempt at a motor comparison is [link=http://www.flyingmodels.org/index_en.htm]The Great Electric Motor Test[/link]. It is by no means complete, but it's quite an effort.
- Jeff
- Jeff
My Feedback: (21)
The numbers are just marketing names. They're meaningless as far as making comparisons or determining if a motor is suitable for a particular application. Ford calls their truck an F150, but Chevy calls theirs a Silverado 1500. Same thing with the motors... 400, 480, 22/33/12... It's just arbitrary, so don't let it confuse you.
Comparing motors isn't easy or simple. In fact, comparing motors to figure out which is "more powerful" is really a lost cause because you can literally MAKE any motor more powerful than another by adjusting battery voltage and/or prop size. Find motors that will do the job, then compare using other means, like quality, price, support, etc..
