E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Power source
Old 08-17-2006 | 07:07 AM
Default Power source
This is not an E-flight problem but I have had such good luck on RCU that I thought I would see if anyone had an answer or could point me in the right direction.
I have an old cassette player that has a 6VDC input on the side. Anyone know a practical (preferrably inexpensive) way to get 6 volts from my 12 volt car? I would guess the unit draws 50-100 mW.
Thanks -- John
Old 08-17-2006 | 08:12 AM
Mitchell91's Avatar
Default RE: Power source
hi, i found this, im not sure if it will stand the amps though, i've used a similar idea to use a lipo as an rx battery
[link=http://www.eidusa.com/Electronics_Voltage_Regulator.htm]take a look[/link]
Old 08-17-2006 | 07:35 PM
Thanks A couple of these and a small 12 VDC fan should turn the trick
John
Old 11-04-2006 | 08:54 PM
I sell coverted pc power supplies ready to go for 30 bucks 12 volts at 15 amps. Search Lammergier in battery and charger ads in airplanes.
