E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
ElectriFly Lipo Problem
Old 10-01-2006 | 10:44 AM
MDK
Default ElectriFly Lipo Problem
I have a new ElectriFly 3 cell 640 mAh lipo that I am having trouble with. I charged it on my Hobbico Field Charger, and when I plugged it into my plane, it barely moved the control surfaces. I tried charging it again, but with the same results, and found that the battery voltage was only 7 volts. Any idea what is going on or what I can do?
Old 10-01-2006 | 12:09 PM
My Feedback: (325)
Default RE: ElectriFly Lipo Problem
A 3S with 7 volts is dangerously low. That may be why the charger did not charge it, although I think it should've thought it was a 2S and charged to 8.4 ? right?
Anyways I think it should have each cell tested and probably find out it is a junker or at least 1 cell is. It is risky to do anything with it.
Old 10-01-2006 | 02:01 PM
MDK
Thanks. I plan to take it to my LHS tomorrow and have them take a look at it.
Also, it says on the battery "15C Max. Discharge" and "Never charge at currents greater than 1C". What does the "C" represent?
Old 10-01-2006 | 02:53 PM
My Feedback: (325)
C just stands for "capacity" so that means 15 x 640 = 9.6 amps max discharge and .64 amps for max charge.
Old 10-03-2006 | 09:29 PM
Matt Kirsch's Avatar
My Feedback: (21)
Go directly to Great Planes with your issue. You'll get quicker results than if you go through your LHS, and you'll be doing your LHS a favor, helping them to remain profitable. Great Planes will almost certainly send you a new pack and a postage-paid envelope to return the old pack.
