electrifly to cellpro conversion
Hello all. I recently purchased the cellpro 4s charger and was curious to see if anyone could explain how to splice the cellpro balancing node onto the great planes electrifly power series batteries' node. Does anyone know any details about how the electrifly balancing nodes are wired? I was thinking it should be an easy fix, it's just that i am not sure how the electrifly batteries are wired...
NY
RE: electrifly to cellpro conversion
Call FMA with their new "deal direct" Im sure they would do it for you.............Oh sorry ......... they fired their customer service dept staff[]
No really you can do it with adaptor cabels from Common Sense R/C 818-206-3384 use a CS2TP 2 or 3 cell adapt with a "reverse" adaptor. That will plug into a cellpro thp/poly board. Call them and they will know. You can also skip the reverse adapt by reversing the wires on the GP cell.
TMC
You can call me for more info
Performance Hobbies
585-872-4990
TMC
Performance Hobbies
585-872-4990
OK, thanks for all the info. One more question. I ordered a few of the cellpro pigtails when i got the charger. Can't i just cut the balancing connector off the electrifly battery and solder on the cellpro pigtail??? If so, which wire from the battery goes to which wire on the cellpro pigtail???
