LiPo + charger/balancer
I will be purchasing another foamy soon...most likely an AirfoilZ model. I have been flying nitros for about 10 years, but recently got my first foamy (GP Yak 55 3D EP). it's pretty stock and I took Tower Hobbies' recommendation on most of the parts. Hence, I have the 22M-1000 Rimfire brushless and the Electrifly 1500mAh 8C LiPos.
I will be building my AirfoilZ w/ better components and wanted some suggestions on a good charger and balancer (I need a balancer right?). Also, are Apogee batteries good? I was looking at some of the 3cell 1500mAh 20Cs. Very nice price! But I don't want to get a crappy battery. The Thunder Power batteries seem pricy, but if they are the ones I should get, so be it.
I'll tell you the charger and balancer I was looking at were the Thunder Power TP-205 balancer, and the Thunder Power TP-535C LiPoly charger. They each run about $60 from www.3dxhobbies.com .
Will a LiPoly charger charge all Lipolys? or will I be soldering and unsoldering plugs all day? I don't know if chargers are proprietary to charging only their brand of batteries (eg. Thunder Power Lipos).
Thanks for any information you can offer...I'm still a bit lost when it comes to the whole power systems thing.
-Erik
P.S. I will be adding balancer plugs to my Electrifly batteries, because there are none on there now....where can I get the plugs to solder on? Are these them [link=http://www.3dxhobbies.com/product_p/csmale4.htm]CLICK HERE 3dxhobbies[/link]
-Erik
RE: LiPo + charger/balancer
The RimFire motors are good little motors. I have them in several planes, and they have been running great, without a hitch.
Personally I stick to Thunder Power. For an extra $10 or so it is worth it to have the top of the line product. They do make a big difference in performance.
I would look at the FMS CellPro 4S Charger/Balancer, for around $55 it can't be beat, charges and balances. You just have to buy the appropriate adapter to charge whatever batteries you get.
I agree w/ that statement. I was mainly wondering because the Thunder Power 15C is more than the Apogee 20C. I take it 20C isn't necessarily better?
What are some key things to look for in a "good" battery OTHER than Specs? The Apogee's sure look alot better on paper than the Thunder Power. Is it the manufacturing process?
-Erik
-Erik
20C is rated higher as far as current/amps is concerned obviously, but if you don't need it, it really doesn't do anything for you.
TRACK RECORD - Thunder Power has the track record of continued excellence and performance. Plus they have a great service/warranty dept. Just about anyone who has put a Thunder Power battery up against an equivalent has noticed the difference in performance that the Thunder Power has to offer.
awesome! That's what I wanted to hear! What does everyone think of the charger / balancer combo I mentioned? Do I really need to splurge on the $200 TP charger?
Thanks for all the help, you guys are awesome!
-Erik
-Erik
ORIGINAL: EpiphoneErik
-Erik
-Erik
