Go Back  RCU Forums > Electric Aircraft Universe > E-Flight Power Sources
 Hacker A50-12S .VS. E Flite Power 60 >
E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Old 10-12-2007 | 10:44 PM
bzyguy01's Avatar
Default Hacker A50-12S .VS. E Flite Power 60
I'm asking this question to anyone that has any experience between the two. I own a Hacker A50-12S and installed it in a 40 size Yak54 @ 6.2 Lbs.....OOPs, The plane was WAY overpowered and I quickley pulled it out! It had 1846 watts w/a 6cell 4200. Yeah....300 wats per lb.!!! Now I plan on installing it in a new 50 size ShowTime 4D. This model should end up weighing around 7.5 to 8 lbs fly ready. This would end me at 245 watts per lb. Probably alot more manageable yet still crazy power to weight. But am I better off to try a power 60 instead? Is there much difference between the two? The specs are very close all across the board but with my personal experience....Hacker has always way surpassed the specs they provide and E flite has usually been alittle overated and fell short from the given specs?
Does anyone have a better power option for this bird?
