Go Back  RCU Forums > Electric Aircraft Universe > E-Flight Power Sources
 Need Help with Multiplex charger >
E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Old 01-27-2008 | 09:32 PM
Default Need Help with Multiplex charger
Hi all! Can someone walk me through using a Multiplex LN-5014 charger? I would like to use it with my Nimh packs. The manual is very brief and assumes you know about batteries. I'm using it in the field as well as at home (on a 12v car battery) to charge and cycle. I have 8.4 v 1000mAh 7 cell packs. I dont know how to set the charger up to discharge. And some of the info on the display I am unsure of. Any help you can provide is greatly appreciated!
Old 02-06-2008 | 10:38 PM
Xpress's Avatar
Default RE: Need Help with Multiplex charger
Umm, why use the charger to discharge the pack, when you can discharge it the fun way
Exactly what does the screen say?
