E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
need to know input
Old 03-06-2008 | 10:28 PM
My Feedback: (12)
Default need to know input
hello all i have a questian if running a 500-600 brush motor and want to go lipo what voltage lipo do i get most i have seen shows 7.4 volts is a 2 cell and 11.1 is a 3 cell thats just some i have seen now what i am asking can the GP 600 T brush motor handle a 3s 11.1 1500 20c battery or do i need a 3s 11.1 1500 15c lipo the esc i am useing is the
30-amp Mini ESC with Brake
E-fliteEFLA106
Electric flyers: E-Flite has packed this new line of speed controllers with features at an unbelievably affordable price!
* For use with Speed 600 motors and below
* Proportional forward w/brake
* 30-amp continuous current
* Thermal overload protection
* Auto cut-off with BEC
* Prewired with connectors
* Input Voltage: 6 to 12 volts
* Dimensions: 1.37 x .71 x0.34 inches
* Weight: .86 oz
Old 03-07-2008 | 12:19 AM
jdetray's Avatar
Default RE: need to know input
The voltage of a 3-cell lipo is rather high for most brushed motors. You'll have terrific performance, but motor life may be short. You can reduce the problem by using a smaller prop, which will reduce current. Or you can try a 2-cell lipo, which will definitely be safe for the motor.
The actual voltage of a fully charged 2-cell (7.4V) lipo is 8.4V. The actual voltage of a 3-cell (11.1V) lipo is 12.6V.
- Jeff
Old 03-14-2008 | 12:24 PM
The Great Planes Elecrifly site is short on real data, but it appears that the 600T is rated at 8-cell (9.6v max) and the one example they give - 8x4 prop - indicates something over 20A on 7-cells (140W). If that is about its limit then you would need to prop for only about 12A-14A max on 3s. Given that, either of those packs mentioned would be more than adequate, though of course the 20C pack (30A max) will hold better voltage under load than the 15C (22.5A max) pack.
