E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
will this setup work?
Old 06-08-2008 | 02:24 AM
Default will this setup work?
I posted this in the other forum but this looks like the place to post it.. it's a typhoon 4w-25 motor in an edf jet with a 2200mah 5-cell 18.5v 15c (25c burst discharge rate) battery
i'm looking for decent performance around the park or air strip but nothing outrageous in a f-20 tigershark .. will this work?
Old 06-10-2008 | 07:35 AM
Glacier Girl's Avatar
Default RE: will this setup work?
Little bit more info would help to get you some answers. Like which fan unit? Which actual F20? What esc?
Just for S&G's I tried the 4w with a Wemo mini 480 fan on 5 cells.
Worked out like this. 16.7 amps, 27.8 oz. of thrust, prop speed of 118.8 mph.
I had the HET F20. It ran the 2w20 motor with the Wemo mini 480. Lot more amps to get decent speed and thrust.
