li-po newbie, how do i charge this thing?
IL
hello, the only li-po ive ever dealt with is the one my blade cp uses, and the charger on it charges straight into the balancing lead, recently i bought 2100 thunderpower li-po's for my typhoons, my p-51 and my fliton but waited to buy a charger to find out what i could use, im on a tight budget for this charger so here are my questions, do i need to be able to balance these batteries? what happens if i dont? does the celectra charger charge directly into the power leads and not the balance lead? i just need a charger for cheap that will work fairly well for me... so if anyone can help me that would be awesome, like said im looking at a celectra because my lhs has them for $45, but if someone else has something a little nicer they would want to part with im still looking.
RE: li-po newbie, how do i charge this thing?
ORIGINAL: destroyer_of_the_blade
If you are looking for a all in one balancer/charger, checkout the FMA CellPro 4s, runs around $75, and you will need the separate Thunder Power adapter card.
NS, CANADA
I second the CellPro 4S. I have 2 of them and they have a built in balancer, are rock solid and idiot proof. I WAS using the adapters but I got a bunch of pig tails from FMA and changed all my batteries to a CellPro balance plug.
My .02 is that I WOULD NOT charge any other way than through the balance plug. I never have and never will.
FMA cell pro 4 is excellent. For what it's worth this hobby is not one that's cheap and if you go that route you will find out why. consider what your flying is it worth risking to save couple bucks on batteries, charger, etc. If can't afford it just wa it till you can.I'm not s aying you must buy top of line everything but do stick with proven products.
IL
well considering ive got nearly $400 in my fliton now and its never left the ground... i think ill budget a little higher for a good charger, ive got a bad habit of just buying whats in stock... i really appreciate everyones .02, as of now im .04 smarter lol, thanks everyone
