E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
My new power system ?
Old 06-15-2009 | 09:35 PM
Ed
Default My new power system ?
I want to use a system consisting of a AXi 2208-34 brushless motor, and a JETI 8 amp ESC, on a 2 cell lipo battery. This is the same system shown on page 58, of the June isse of Model Aviation, in the Zomby.</p>
My primary concern is knowing if the JETI 8 amp ESC is robust enough, to deal with the power surges between the AXi 2208-34 brushless motor, and a 2 cell Li-Poly battery. What do you think ?</p>
Thanks .
Ed</p>
Old 06-16-2009 | 07:53 AM
Banned
My Feedback: (9)
Default RE: My new power system ?
ORIGINAL: Ed
Thanks .
Ed</p>
An 8 amp controller will be marginal at best, Hobby Lobby recommends a 12 Amp for your size motor. I have 3 of them in different planes and use an 18 AMP. You are only talking a $4 difference between an 8 and a 12. For another $4 you can take it to 18 amps. When in doubt I find it best to follow the manufacturers directions.
Old 06-16-2009 | 12:30 PM
It is recommended max 8A. The ESC would do the job if you stay within specs. I would guess an APC 9x4,7SF on 2S is max load then.
Old 06-16-2009 | 03:10 PM
Ed
ORIGINAL: Red Scholefield
<span style="color: #3366ff">" Hobby Lobby recommends a 12 Amp for your size motor. "</span><span> </span><span>OK Red, I didn't know this. I'm glad now that I asked. Then it's gonna be a 12, or an 18 amp unit. Do you know if the 18 is much heavier then the 12 ???
Thank much.
Ed</span>
Old 06-16-2009 | 06:51 PM
Banned
My Feedback: (9)
ORIGINAL: Ed
Thank much.
Ed</span>
Jeti 12 amp = 10 grams, 18 Amp = 21 grams per the Hobby Lobby catalog
