RCU Forums
-   E-Flight Power Sources (https://www.rcuniverse.com/forum/e-flight-power-sources-126/)
-   -   Li-Poly esc (https://www.rcuniverse.com/forum/e-flight-power-sources-126/1575305-li-poly-esc.html)
gummy_cow 02-29-2004 01:20 AM
Li-Poly esc
I am going to get a Li-Poly 2 cell Kokam 700 mah. I was wondering if my Great Planes C-10 will handle this li-poly pack. My friend uses a GWS 5 amp speed control and he hasn't have any problems. Just wondering. Also if the C-10 wont work what is a good esc to use?
crewchief_432 02-29-2004 09:17 AM
RE: Li-Poly esc
You can use the c-10 but you have to watch your flight times, You cant run the lopolys below 3v per cell. If you wantes to get on for lipolys I would get a caslte creations pixie 20 there about the same size as the c-10 they have a low voltage cut off.
gummy_cow 02-29-2004 01:51 PM
RE: Li-Poly esc
thnx it looks like a good esc.
