Help with LiPo selection
Hello all,
I like to know what should be the recommanded LiPo that I should use for the below configuration? I'm using a RimFire 35-30-950 Brushless Outrunner Electric Motor on a plane with the following specification Plane specification 38" Wingspan Semi scale 30" long 225 sq. in wing area 21 0z. flying weight Motor specification kV Rating: 950 rpm/V Weight: 2.47oz (71g) Input Voltage: 7.4-14.8V Max. Constant Current: 20A Max Surge Current: 28A Max Constant Watts: 296W No Load Current: 0.8A Suggested Prop Sizes: 10x5E - 12x6E Thanks Borna |
RE: Help with LiPo selection
Thunder Power 3 cell 11.1 volt 2100mah Pro-Lite 15C constant 20-24C burst
I agree, i use that same battery on a plane with about the same specs. I used a couple other brands in the 2100 mah range also and they worked but just didnt have the punch and run time of the thunder power cell. I was thinking of trying one of the extreme cells to see if it gives me even more, but i guess it would just be overkill since the plane will never tap into that many amps anyway.
happy flying |
hey, i just checked the site that i buy batteries from and they have them on sale. thunder power 2100 3 cell for $59.99
here is the page, http://www.superfastrc.com/11volich.html one thing also about that plane, it really seems to make a difference to run a deans connector also or something similar that will carry the amps. |
| All times are GMT -8. The time now is 03:38 AM. |
