RCU Forums
-   E-Flight Power Sources (https://www.rcuniverse.com/forum/e-flight-power-sources-126/)
-   -   Can 2+2=4 (https://www.rcuniverse.com/forum/e-flight-power-sources-126/5642395-can-2-2%3D4.html)
pikeman401 03-30-2007 09:31 PM
Can 2+2=4
For some reason when I started out in electrics I ordered 2 two cell (7.4 volts) 2000mah packs. Why I ordered them I have no idea, but I have them and I don't want them to just collect dust. Now some of the motors I have will run on 4 cells. Can I take a red lead from one and connect it to a black lead from the other and use the other red and black as the batt connector to get a 4S pack? Basically connecting them in series without taking them apart and soldering them together in one pack?
jdetray 03-30-2007 10:33 PM
RE: Can 2+2=4
Yes, you can do this. You'll end up with a 4S 2000mAh battery. FMA even makes a connector module to make this sort of connection easier:
http://www.fmadirect.com/detail.htm?...971&section=56
- Jeff
packyj 03-31-2007 09:42 AM
RE: Can 2+2=4
Well,
1/3 = .3333333333333333~
so 1/3 * 3 = .999999999999999~
So 1+1 does not equal quite 2 and therefore 2+2 doesn't quite equal 4.
other than that jdetray hit it right on the head. It's actually a good way to buy for 4 cell packs as you then have two 2 cells to use in smaller planes if you wish.
pikeman401 03-31-2007 10:27 AM
RE: Can 2+2=4
Great !!! Four cell packs don't come cheap. Thanks for your help
