Blade SR ESC help
CA
Can I use a Scorpion 25 amp V2 ESC for my BSR? I see the Eflight ESC has a second plug that plugs into the Eflight gyro. If I unplug this wire going INTO the gyro the tail spins full speed.
I am thinking that the wire going INTO the gyro is a signal wire that tells the Eflight ESC how much power to send to the tail motor?
If I upgrade to a belt driven tail can I then use the Scorpion ESC?
Thanks for any help.
CA
It just dawned on me, I think! When upgrading to the belt driven tail I will then plug the servo that controls the tail pitch into the Gyro right? Then the gyro plugs into the rudder channel on the reciever right?
