Blade SR and CPP2
Ihave a blade SR, I want to turn it into a slightly better machine than it is right now. would i be able to put a CPP2 head assembly and swah onto a blade SR? i dont know if the shafts are the same diameter/length to fit the different head, but i'm sure i can make a shaft to fit the main gear and frame from the SR AND the smaller/larger head from the blade CPP2.</p>
