E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
servos
Old 02-22-2011 | 02:54 PM
Default servos
Ok i just installed all new servos on my 400. ds 285 and a ds290g and a g270 gyro.Now am i correct in saying that you have to reverse all of them with the exception of the throttle and rudder? And also my rudder won't center when you neutralize the stick is this normal when it is sitting still but then it will also do it when it is spun up.Thanks
Old 02-23-2011 | 05:52 AM
BarracudaHockey's Avatar
Default RE: servos
You have to check the control direction, merely replacing them doesn't mean you have to reverse them.
With a heading hold gyro it wont recenter the tail servo like a normal channel while its sitting on the bench.
Old 02-23-2011 | 07:41 AM
Default RE: servos
Thanks thats what I thought but being new to the sport u never know.I never read where somebody had to reverse a different servo that they had installed butI figured that was the case.</p>
Old 02-23-2011 | 08:07 AM
Default RE: servos
I'm just saying check it first, if you were to say switch a futaba out with a hitec then yes you'd have to reverse the channel. It just depends on how the servo's are wired inside.
Old 02-23-2011 | 01:06 PM
Default RE: servos
Thanks up here in northern montana there isn't to many heli drivers so I thank all of you on these forums for the advice and knowledge.Also are the set up degres for the main rotor the same when you are in 3D versus normal mode?
Old 02-23-2011 | 02:07 PM
Default RE: servos
I do because I don't like the helicopter jumping around when changing flight modes, also in an emergency I don't have to think about any switch flipping
Old 02-23-2011 | 04:35 PM
Default RE: servos
could somebody pm me with a phone number so I could talk to a person about reversing these servos insteads of tying up a forum thanks
