triming??
When i fly my blade sr the tail always spins to the right so i am always having to hold the stick to the right which is very annoying. I know what you'll probably say is move the trim but its is all the way over so i can not move it any more. is there anyway i can adjust this??
QC, CANADA
Did the heli start to behave like that recently? Did you crash? The gyro is what should retain the tail of the heli in relatively the same place without rudder movement. Is the gyro held in place correctly? Any unnecessary vibration on the heli?
when i got it it worked fine but then i crashed it and then it straiten to do that. And last time replaced the gyro i didnt think it was completely centered so i will place it again tomorrow after school, and test it.<div>thanks</div><div>Connor</div>
QC, CANADA
A gyro needs adjustment. You should refer to the manual on how to set it up, and adjust the gain. The pods on it are very sensitive. No need for a lot of adjustment.
