mSR main motor replacement
I think I burnt my main motor on my mSR and am about to replace it but it looks like it is glued to the frame. What kind of glue/tape should I use for the new main motor. Don't want to use Super Glue since it wont be able to replace it in the future.
RE: mSR main motor replacement
i removed my motor for rebuild once and melted a tiny hole in the frame for a screw(from the screw kit) that tightens to lock the motor in.
Formula87
Yes I used the stock motor and I just slided it into the frame and it's pretty snug in there. Only once after a couple of crashes did I see it move up a little but not too much.
