E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
CX2 Bodies
Old 06-27-2011 | 01:30 PM
Default CX2 Bodies
Where can I find some custom CX2 bodies? All I can seem to find are different variations of the stock two piece... I'm running a tail boom so all I need it the front half.... Something streamlined with a front window thats transparent.... Thanks for any suggestions/links..
Old 06-29-2011 | 04:37 PM
Default RE: CX2 Bodies
Guess I'm stuck with stock bodies.. That sucks..
Old 07-03-2011 | 02:24 PM
You can buy clear bodies from Boomtown and paint them yourself - The outside comes masked. Tape the inside that you want clear, and paint the inside with Krylon spray paint. Peel off your tape and the outside masking when your paint is dry. BTW, 2 thin coats are better than one drippy one.
Old 07-03-2011 | 03:25 PM
ORIGINAL: AH-64_d
Thanks, I checked here http://www.boomtownhobbies.com/Xtrem..._p/bcx009c.htm but didn't see any clear bodies, that would be ideal..
Old 07-04-2011 | 08:14 AM
I believe that it was an Extreme body - I had decals and such that I ignored.
Old 07-04-2011 | 04:01 PM
Im somewhat confused, do they have clear CX2 bodies or no?
Old 07-05-2011 | 12:37 PM
They did, at the time... You also might check Helitek. Either way, I am kind of puzzled as to why they do not seem to be available, now.
Old 07-05-2011 | 04:13 PM
Just got an email from Jamie at Boomtown, they now have clear CX2 bodies in stock..
