Battery For Blade CX
LA
I was wondering if anyone new of a battery that is a little bigger than the lipo that comes with the blade cx, and also if I upgrade the battery to a stronger 2 cell do I need to do any other modifications? Any help would be appreciated.
Thanks, Mike
Thanks, Mike
RE: Battery For Blade CX
MadRigger,
Look at helidirect.com and you will find good deals on batteries. If you stay with a 2 cell 7.4 volt lipo, you do not have to do any mods to the 4-and-1. If you go to a bigger mah, you will have to mod the battery mount. You may find that the weight of a higher mah bat is not worth it.
