My BCX is actin just plain WEIRD
CO
Ill go through the process.
I turn on the transmitter and plug in the battery. The servo doesnt put a light on. I add throttle and put it down again and the light gives 1 green flash, then solid.
(whats with that?)
Next when I add enough throttle to lift it up, even though trim is on FULL top and left, it goes back and right without cryllic input. and when i try to stabelize (oppisete back and right) it wobbles and falls to its side.
I never had this happen before, and its freaking me out!
(whats with that?)
RE: My BCX is actin just plain WEIRD
Check for servo reversing (and undo the reverse from ur transmitter) or it could be interference from somewhere else....I don't have time to fully analyze the problem but work with what i told you so far...good luck
