Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
 Modified CX- forward flight?? >
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 06-18-2006 | 04:04 PM
Default Modified CX- forward flight??
Hi im new to these forums but theres a lot of great info here.
i was wondering what kind of forward flight experience people have had with a modified blade CX. Specifically the mod where you cut out huge holes in the canopy to get better airflow to the 4-1 and the engines. Also, I was wondering if the heatsink available for the BCX is a worthwhile investment.
thanks
Old 06-18-2006 | 05:30 PM
Default RE: Modified CX- forward flight??
Heatsink is a good idea. Heat leads to the ultimate failure of the motors. Even with the heatsink on, the motors run fairly hot. Good idea to use the heatsink compound to disperse heat also. Some people have blackened the motors with a "Sharpie". I guess this distributes the heat a little more. Can't say for sure if this works.
I have had no issues with venting the canopy. Foward flight is the same. I like to fly outdoors, this helps with the heat, but it has to be calm outside.
Old 06-18-2006 | 08:44 PM
We have done major cutting out of the canopy above and below the 4-1 as well as next to the motors.I have noticed no difference in forward flight.I do notice that the 4-1 runs cooler
