charge cp battery
NY
i have a turbo 35 and want to charge me battery pack for my cp.how many amps should i set the charge rate?i won't have to worry about over chargeing. should i discharge my pack when i'm done and if so how many amp discharge?
VA
The factory says 850 mAh max, but 1 amp should be fine. I'm new to the whole electric thing, so I had a nice long talk with the local guru, and this is what I was told. Seems to work OK for me so far.
MI
Manual states 0.85A for charging. I charged my first few cycles at .75A then bumped up to 1.0A. Just keep an eye on the battery and make sure its not getting over heated while charging at the higher amp setting.
