E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Blades for the CP Pro
Old 11-07-2006 | 08:20 PM
Default Blades for the CP Pro
Am I right by thinking the blades for the CP Pro are 225mm? Can I turn 325mm blades, will it hurt anything.
Thanks for the help
Mark
Old 11-07-2006 | 10:40 PM
Heli_Harry's Avatar
Default RE: Blades for the CP Pro
ORIGINAL: mark126804
How far is your tail rotor from your head?
Old 11-08-2006 | 02:23 PM
Well, I picked up a lexan fuse of a UH-60 Blackhawk, so its further away than the stock set up. But I am considering on using the direcdrive tail motor, that Nick ????? is using, its the GWS motor with the 3x2prop. And I'm still not sure if I should use the Himaxx 2015-5400kv, or just use the Park 370-4100kv(or Himaxx2015-4200kv). Just wondering.
Thanks Mark
