E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
tail motor
Old 12-25-2006 | 11:25 AM
Default tail motor
Hi their to all blade cp owners. I heard that you have to replace the tail motor after about every 20 flight or battery packs. Is this really necessary? Thanks
Old 12-25-2006 | 11:59 AM
lwatson's Avatar
Default RE: tail motor
You will notice when it is necesary because the tail becomes erratic. Or you run out of trim, Just watch for it.
Old 12-25-2006 | 12:13 PM
thanks
Old 12-25-2006 | 03:38 PM
Mine became erratic, I compensated with the gain and proportional...it lost the ability maintain power to hold the tail at all when I declared it dead. Some of the things I've found:
* try not to slap the tail on the ground while hovering (can't be good for it and you can hear your tail rotor blades slapping).
* don't overspeed the tail motor and make jerky corrections to the tail (smooth and even on the stick).
* try not to drop the heli out of the air quickly (hitting the heli hard on the ground). Make as smooth of a decent as possible.
If you're still in the learning stage, you'll have to do some of the above just to avoid wrecking the unit. I had to buy one new tail motor, and I'll have to buy another...it's a given.
Old 12-26-2006 | 03:23 PM
Heli_Harry's Avatar
You may want to think about going to dual tail motors or DD.
I have not burned out a tail motor since going to dual Tail Motors.
Have Fun!
Old 12-26-2006 | 06:40 PM
I have a DD motor coming in the mail with other crash parts, is it a direct replacement, the only addition needed being a prop retainer?
