BLADE CX GEAR PROBLEM
I just got a blade CX for Christmas and got it flying just today. Inner shaft gear (lower gear) is getting it's teeth all ground up! Now it wont fly. I just upgraded the inner shaft to aluminum and was wondering if I can do the same with gears. If not can a buy JUST the gear without the shaft. Please help me solve my problem
Thanks in advance!!!!!
KS
once you replace the gear, check the gear mesh with a piece of paper between the motor pinion and the gear. a mesh that is too tight might tear up the gear.
