E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Cx2 To BCPP
Old 01-15-2007 | 09:50 AM
goplaneman's Avatar
My Feedback: (175)
Default Cx2 To BCPP
Is This a good move? and if it is, Should I set it up diffrently from the way it comes? (Maybe flat blades?) I would like to uses my 8103H, Will a crystal from Jr worke in a E-flight receiver?
Old 01-15-2007 | 12:05 PM
bzinfinity's Avatar
Default RE: Cx2 To BCPP
Will it be your first time flying a CCPM machine?
If so, get the training gear, do RADD's, and you should be fine, I would leave it stock while you learn.
Old 01-15-2007 | 10:30 PM
goplaneman's Avatar
My Feedback: (175)
What do you think about switching radios? I could turn the throws down with the 8103.
Old 01-15-2007 | 10:48 PM
you have to have a heli radio that supports that fancy collective/cyclic mixing that the BCP uses. it would probably be better to just take some tension out of the stock radios centering springs, since thats the main problem with the stock TX.
Old 01-15-2007 | 11:43 PM
goplaneman's Avatar
My Feedback: (175)
My 8103 is a heli radio, but I can try out the stock TX.
