Upgrade motors?
CA
RE: Upgrade motors?
hmm, ball bearings on a non-rebuildable brush motor... they should work. the esky lama is basically a clone of the cx, which has the same motors as the cx2. if they work with the lama, they'll work on a cx2.
most times bearings are a waste of money unless you put serious hours on a motor (ie: rebuildable or brushless). so i wouldn't spend too much more on those motors unless they are noticeably more powerful/efficient.
[edit: i noticed they didn't put a capacitor in the pic. if they come without one, you may want to install one to prevent glitches.]
FL
RE: Upgrade motors?
I've had my eye on those too. They have replaceable brushes and I would expect some performance gain as well as smoother running from the ball bearings.
Are you saying that you have them or just that they are available. I wouldn't mind being the Guinea Pig and spend the money to test them, I even have 2 BCX2s so I could do a side by side but I probably wouldn't get around to it for quite a while, I was hoping someone else would.
Also, they seem to be available only from the place you linked to, I rather add them to a "parts" order so they don't come to $20 each with shipping.
CA
RE: Upgrade motors?
ORIGINAL: bigbore
i would expect some gain in efficiency with bearings, but not enough if we're talking about $20 motors.
just talking from years of experience racing r/c cars with brushed motors. in racing, it's all about the comm. the fastest racers would use brushes for 3 runs only, but they'd cut the comm and reseat the brushes every single run to keep peak performance... and bearings are only aloud on modifieds, which crank out over 20A constantly (even stock class motors with bushings crank over 20A, and they last forever as long as you shaved the comm regularly). even with modifieds, it's all about the comm, although they burn brushes easier if they aren't geared perfect. i doubt the bearings and replaceable brushes are worth that much. maybe if they came out with a hotter motor that was only a couple bucks more we'd be talking (ie more power/shorter life). the reason they probably haven't is helis aren't like cars, more power isn't necessarily good if it means terrible efficiency or reliability in the air.
i know you guys are probably going to roll your eyes at me, but if you want more power & reliability, why not go brushless?
[edit: btw, this talk about racing reminded me of gearing. if that motor has a different winding count than the stock motors, you'll probably have to change the gearing to keep things efficient. generally, hotter motors (lower # winds) use less teeth on the pinion.]
RE: Upgrade motors?
I went ahead and ordered a set of these motors. If you go onto the webisite and look at the detailed pictures, they do indeed have capacitors installed. On the downside, these things are actually coming from Hong Kong. I'll let you know how well they fit on a CX/2 as far as mounting, electrical connectors, etc. It's a pretty safe bet for me... I'm an engineer by profession and I'll make them work no matter what. However, it'd be nice if they were perfect drop-in replacements. I'll keep you posted. Neall
PS: I'll caliper the pinion diameter and do a tooth count. I suspect it'll be compatable as well. I'm pretty sure the eSky Lama shaft gears are the same size and tooth count as the CX, as well as the Dynam Vortex. One way to find out.
RE: Upgrade motors?
I think they'd probably last longer and put out more power than the Vortex motors. Their probably quieter too from the bearings, and they give you the option of using silver brushes for 30% more torque. They wouldn't last forever because you can't rebuild them, but they would probably last longer than the others because you can swap brushes. I dunno if you can get a significant amount of extra service out of them they might justify the cost.
FL
RE: Upgrade motors?
No, on the contrary, I'm here to learn from people with experience. One thing I noticed years ago when flying RC fuel planes was the ball bearing engines ran smoother, quieter and almost twice as long on the same amount of fuel compared to bushing engines.
I'm not into spending a ton of cash on my BCX2's, if I pour money into any of my heli's it will be the BCPP's, but if I can put together a nice smoother running and quieter BCX2 I might swing for an extra $10 on a set of these motors when the stock set need replacing. I'll be looking for smoother and quieter and would expect longer life although the stock motors have given good service so far.
ORIGINAL: Truglodite
CA
RE: Upgrade motors?
i used to have a k&b sport .21 motor with bushings over 20yrs ago (that thing ran smooth and quiet, but had no power). ever since i upgraded to my first bearing engine, i never again got bushings for my nitro airplanes. when it comes to electric motors though, properly oiled bushings will perform very close to bearings for as long as the comm will last. $10 isn't much by itself, but when you consider everything else involved with helis it adds up quick. then again, if the heli flies so much nicer that you enjoy flying much more... it's worth every penny.
RE: Upgrade motors?
Ok!!
Thanks! for all the suggestions and tips you guys give!
I'll go ahead and order them and give a try on my bcx2.
As i'm in asia and HK is only a few hours flight, it will be here 2-3days.
I also ordered the Lama hard blades and try to mod it to see whether it fits my DIY blade holder.
CA
RE: Upgrade motors?
that's $100 less that could go towards a trex.
Original: mbx5prospec
The one who comes up with a brushless system to work with CX2 and keep the around $100 will be king...
RE: Upgrade motors?
Has anyone tested these motors yet? Compared to Vortex? My motors look like they are just 10 bat packs away from dead. Lots of gold dust/residue on the chasis.
I'd like to replace them with the best available option.
Thanks for the info![8D]
FL
RE: Upgrade motors?
FWIW, I keep track of how many charges are on my batteries. My BCX2 batteries(4) have ~ 150 charges on them combined. One of my BCX2's(heli) has ~ 2/3 rds of the combined flight time on it alone and I don't see any slowing or obvious signs of failure yet. I do let them cool down between packs but other than that they get whatever two noobs can dish out.
