Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
 CX, CX2 and Vortex and ?????? >
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 01-20-2007 | 10:17 AM
DaveG55's Avatar
Default CX, CX2 and Vortex and ??????
I know that the CX, the CX2 and the Vortex are virtuall identical (except for the electronics) but aren't there a couple more that are too? Which ones are they?
Old 01-20-2007 | 10:42 AM
ndoren's Avatar
Default RE: CX, CX2 and Vortex and ??????
It also shares some parts with the eSky Lama. Motors and shafts, as far as I can tell.
Old 01-21-2007 | 04:36 PM
DaveG55's Avatar
any others?
I had heard the eSky had some parts that would work. Anybody know how many parts are interchangable?
Or any other helis with parts that fit the CX / CX2?
Old 01-21-2007 | 08:26 PM
As far as the eSky Lama and the CX/2 are concerned, there are only a few parts that are interchangeable...
1. The outer shaft and main gear are identical.
2. The bottom gear is identical, but the inner shaft is different. So, if you swapped a Lama's inner shaft witha CX/2's , you would have to use the CX/2's blades. But, then your upper and lower blades wouldn't match, and you would have to get the CX/2 lower rotor head and blades. The inner shafts are the exact same length, but the upper rotor head has slightly different spacing than the CX/2. Also, the kinkage on the flybar is just a little bit shorter on the Lama than the CX/2 and so is the flybar (just by a very small amount). It also has a slightly different ball-connecter which is smaller too. So, you would have to do some slight modification to interchange these parts...
3. The motors are identical even though they are mounted in different locations.
4. All bearings and mounting collars (including top collar).
Other than that, that is pretty much it. It is actually quite a bit of work to interchange parts between these two helis, but it can be done for some things very simply. I hope this helps...
Old 01-21-2007 | 10:20 PM
DaveG55's Avatar
Does the eSky Lama use a 4-in-1 like the original CX. Would they be interchanable? If so, what's the cost like?
Old 01-21-2007 | 11:23 PM
Why everyone is so into swapping the Blade CX/CX2's nice 4-in-1 with one of those slop-togethers from competing cheaper models is beyond me! I'm sticking with either E-Flight or separates.
Old 01-21-2007 | 11:50 PM
I guess the lama's 4-in-1 would probably work with the cx... Don't know why you would though, I'm sure it costs just as much...
Old 01-22-2007 | 12:32 AM
Hmm..... Well if cost is the object here then the easy solution is not to leave your throttle pinned in a crash like a newbie. Do that and there's no reason to have to buy a cheaper 4-in-1.
Old 01-22-2007 | 02:39 PM
DaveG55's Avatar
ORIGINAL: neilt6
You're making unwaranted assumptions there, aren't you? First you have no idea of my skill level or my flying habits or why I'm asking or the events that lead up to my asking. Also, I asked what the cost was like, not is it cheaper. I did not say I was looking for a less expensive alternative, in fact, I'm just exploring and asking what's available.
Besides, those "nice" 4-in1's sure do seem to have a high failure rate. Even several of the more experenced flyers have had issues with them.
Old 01-22-2007 | 02:58 PM
ndoren's Avatar
I read in one of these threads that someone said the Dynam Vortex 4-in-1 had fewer tail drift issues than that found in the CX. Can anyone confirm? I assume they're interchangeable (perhaps with a bit of modding).
Old 01-22-2007 | 04:19 PM
Hey guys! I just got the Vortex inner and outer shafts for my cx2, and I was wondering if anyone has actually done this and knows if there is anything I should look for as in problems or something. Thanks!
Will
Old 01-22-2007 | 05:08 PM
DaveG55 - I'm sorry if I insulted you. I just can't figure out why some people know they arn't supposed to leave the throttle pinned but still do. I got into the habit of killing the throttle if I was going to hit something because I didn't want to break blades as my LHS isn't so local.
ndoren - I think the vortex units are open backed to expose the boards, meaning they wouldn't heat up as much as e-flights. Everybody figures the drift is caused by heat so....
Old 01-22-2007 | 07:04 PM
DaveG55's Avatar
I chop my throttle when it goes in too.
Unfortunatly that's not the only cause of 4-in-1 failure. Several people have had issues where the 4-in1 just seems to quit working properly. My 4-in-1 worked great one day - no wrecks - and the next day it only provides enough power to lift the CX about a foot high and that only lasts for a couple minutes. I've rebuilt the heli, replaceing with new, both shafts, all blades, and gears, flybar and verified that the bearings are smooth and that both my batteries are good. It still won't lift properly. I don't know what happened but I've read of several people having the exact same experences and results.
I've also read of people having good luck with the Vortex 4-in1 and the last time I saw one it was $35 which is a pretty good savings over the e-flite one ($50) and if it does not have the tail drift issue it might be worth the gamble to try one.
But that's not really why I started this thread. I was really just courious which parts were interchangable between which helis.
