E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
BCPP troubleshooting
Old 01-27-2007 | 09:21 AM
Default BCPP troubleshooting
I'm new to posting here, but i've gone through posts many times for info.
I'm new to heli's and just recently replaced the paddle pushrods and main shaft and gear on my BCPP
Now when I try to hover it, it will lift off fine under normal power then drop to the ground after a mear 2 to 4 secounds of flying. I dont notice any power change in the motor, neither do I notice any binding in the links. Nor do I notice any glitching with the receiver.
Any input on this problem would be much appreciated.
Old 01-27-2007 | 01:13 PM
lwatson's Avatar
Default RE: BCPP troubleshooting
Is it lifting off at 2/3 throttle or at 7/8 throttle? Also check the spindle between the blades to make sure it is not bent.
