E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
bcx2 throtle mod oops
Old 01-30-2007 | 05:48 PM
davewithx's Avatar
Default bcx2 throtle mod oops
Ok I was doing the throtle mod on my cx2 and I droped the screw. do any of you know what size it is?
Old 01-30-2007 | 06:19 PM
Default RE: bcx2 throtle mod oops
throttle mod? are you talking about removing the detent on the collective stick?
anyways, finding micro sized hardware is not easy. in fact i've had troubles finding a common mounting screw for the popular gws ips motors that everyone on the planet is using. your best bet is to dig in your boxes and see if you can find one that fits. if it's tapped in plastic, almost any similar screw will work. if it's a machine screw, well...
Old 01-30-2007 | 08:35 PM
Not sure of the size of the screw, but for what it's worth Radio Shtuff has small screws included with some of their XMODS tools and parts. You may also find what you need in a glasses repair kit found in a lot of checkouts or drug stores.
Old 01-30-2007 | 10:32 PM
davewithx's Avatar
thanks for the help guy's. I put the screw on the table, grabed my plyers to adjust the bar, turn around and the screw grew little legs and ran off the table. Doing a perfect half pike with a double twist right in to the carpet. I ran the vacume over the area for search and rescue, but to no avale. [&o] I will try your guy's ideas. thanks
Old 01-31-2007 | 10:12 PM
I lost that screw too, its listed in the blow up or breakdown of the copter and has a part number and size.....and it does come in a parts kit from e flite. If all else fails look in your manual.
Old 02-01-2007 | 01:54 AM
lessons learned:
-use a magnetic parts dish
-keep your manuals
Old 02-01-2007 | 07:25 AM
Same size as the one on my 1980 futaba 4 channelDon't ask me what size it is, but it worked fine! I threw mine away because I wanted the smooth throttle, and by the time I figured out that I DIDN'T want the smooth throttle, the trash guy had already come[]
Old 02-01-2007 | 08:20 AM
davewithx's Avatar
I still have the manual. but mine dosn't have a break down for the controler. but I'm just going to put whatever I can find in there.
