CP Pro on G3.5 Simulator
It's actually pretty easy. With G3 open, click: Simulation>Import>G3x Then find the file and double click. the program will import the file and you will get a status message at the bottom of the screen.
If never imported anything into G3.5 you need to do an export first. You are not really exporting but you initiate an export for the import to work. After you done it once you don't have to do it again.
If you don't your G3.5 will lock up everytime you try to import until you do an export once.
MI
Thanks guys I imported successfully, can anyone comment if the CP Pro sim is accurate to the real bird? I hope it is before I spend hours flying it.
this thing is a rocket!!!!
is it supposed to be brushless/HH? I could do anything with it. Tic tocs, piro flips, you name it! If the real one flies like that brushless I'm changing! Don't worry. If you can gly this one you can fly the real thing. Its just MUCH more responsive and powerful in the sim
Remember the simulator is meant only as an aide. There is no substitute for actual flying on the heli in question.
That being said, I agree with AeroDave, this particular sim model is more responsive and trickier to fly compared to the actual CP Pro. IMO.
