blade cp pro tail rotor alignment
FL
Best way I found to do it is plug in battery and center controls and trims (except throttle). Attach the tail support so the tail rotor shaft is level with the swashplate (make sure your swashplate is setup right before you do this). Most important thing is to avoid glueing it on so it angles up to the right. That will push your tail down.
FL
