replacement bearing!!
I was removing the main shaft that has the large spur gear on it that connects to the motor. While doing that, I had trouble sliding the parts of the small hole that the retaining pin goes through and unfortunately, one of the BEARINGS was ruined. I need to replace it, but the schematic doesn't tell me which size bearing it was. The parts list tells me theres a 2x6x3mm and a 3x6x2.5mm. I can buy 2-packs of each bearing.
Does anyone know which bearing replaces those that plug into the black plastic, that hold that main shaft with spur gear in the chassis????
RE: replacement bearing!!
look down about a half of a page, and you will find that I just answered this q yesterday
http://www.rcuniverse.com/forum/m_5600292/tm.htm
no offense or anything, but sometimes it does help to read a bit
hope ya get it back in the air soon =)
Yep...I see that now that the question got answered there. I did see that post there, but I guess I didn't think I'd get my main rotor question answered in a tail rotor post
yeah, that is definately true... you wouldn't expect a main bearing question to be answered in a tail post =)
hopefully that helped you out though =)
Next time before pulling a bearing and ruining another one, just file the shaft with some sand paper or a light file. This should take the bur right off and your bearing will come right out. Heli007
