Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
 Need bcpp electronics help. Red/green flashing >
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 05-06-2007 | 10:10 AM
noguy's Avatar
Default Need bcpp electronics help. Red/green flashing
Super bummed pilot here. The other day I installed a new motor (orion slowmax 300 brushed motor)...test hovered in by....thing was working like a dream with all new amounts of head speed and main motor tourqe......Went out to do some real flying at the field down the street and next thing I know it is glitching like crazy then not working at all. The led in the 3in1 would flash red/green. The servos were still working. Then after a little tinkering and re-arming the whole thing was dead servo too now. Except for the dumb blinking red/green led. Ok so I just fugured maybe the new motor was too much for the 3in1 but many others have this motor pluged into the 3in1 with no troubles so figured that I would tinker some more.
I found I can get everything to work nornmally if I apply sideways pressure to the channel 4 plug right at the reciever. I then found out that the pressure applied to other plugs wake everything back up or presseure applied to the whole group of plugs so I am thinking that I have possible fractured the circuitboard in the Rx in the many crashes this bird has seen.
I am wondering has anyone seen this before? Has anyone taken one of the Rx's apart and successfully repaired it or is this a complete waste of time? Does my assumption about the Rx being damaged sound correct?
Any input would be much appriciated. I want a new Tx/Rx soon so I dont want to keep dumping $ into this pos eflite radio equipment.
Thanks, Noah
Old 05-06-2007 | 05:34 PM
Default RE: Need bcpp electronics help. Red/green flashing
sounds good to me, and alot of people have taken apart the receiver and soldered pins back on and stuff like that. here are a few pics of the 4 in 1, but the concept is simular. You would obviously be opening the receiver and not the 3 in 1
http://www.heli-max.net/mediawiki/index.php/Brushless2
http://www.rfcafe.com/references/art...P%204-in-1.htm
Old 05-06-2007 | 10:23 PM
noguy's Avatar
mrasmm,
Thanks for the help.
I got in there and checked everything out and found that the board seemed just fine. I then realized that the problem was my own foolish tinkering out in the field. I allowed some overspray from CA insta-cure get onto the back of the connectors and it wicked in and caused a poor connection on a couple of the connectors in the Rx. Another hard lesson learned.[&o]
Those pictures you gave a link to are excellent.
Old 05-06-2007 | 10:55 PM
good to hear you got it figured out... no one would probably have ever guessed that problem from over the net =P
glad to hear you are up and running
