E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
lipo charging
Old 05-09-2007 | 03:07 PM
Default lipo charging
which is quicker. to charge using the wall charger or hooking up to 12 volt battery or about the same amount of time.
Old 05-09-2007 | 03:23 PM
Default RE: lipo charging
Should be the same time. The charger either charges at 600 mAh or 800 mAh (depending on weather you have a CP or CPP, respectively).
Old 05-09-2007 | 04:54 PM
thanks. i figured that would be the case but sometimes dc charges alot quicker then ac
