Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
 DX7 setup for Blade CX2 >
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 05-14-2007 | 06:35 PM
Balance's Avatar
Default DX7 setup for Blade CX2
HI Everyone. [8D]
I just got a DX7 and got it setup on my Blade CX2. I have it flying but I had a lot of tail drift (gyro taking to long to stabalize), and I
got it down some by putting my Gyro Sensing to %57. It still has a little tail drift. Who has a good setup I might try?
I did a seach on here and didn't see anything listed. Sorry if this topic has a tread already.
Balance...................Fly Right
Old 05-14-2007 | 06:43 PM
Default RE: DX7 setup for Blade CX2
welcome to the group =)
I dunno if you have seen this, or if it would help you because your problem is more specific, but check this out
http://www.horizonhobby.com/Articles...ArticleId=1658
Old 05-14-2007 | 07:23 PM
p01rogue's Avatar
Yep , that horizon setup worked perfect for me.
totally recommend it.
Old 05-14-2007 | 08:15 PM
Balance's Avatar
Yeah, I seen that setup page before I bought my DX7. I got the DX7 as I will be running it on my Cx2, Flite Sim , and I am building a T-Rex 450seV2.
I will have to try the Acro setting again I am sure that probably works good, I just picked the Heli to see what I could do with it.
Balance ____^____
Old 05-14-2007 | 09:01 PM
The CX-2 (any of the electric co-axes) is only an airplane.
With no throttle curves or pitch curves to worry about, just get the pitch and roll responses correct with dual rates and expo.
Any drifting in yaw can be diminished by adjusting the speeds of the rotors.. getting both of them to start at the same time using the proportional control will help, but the battery drain as the flight goes on always makes the thing drift in yaw.
