E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
CX2 blade replacement
Old 07-25-2007 | 12:09 PM
Default CX2 blade replacement
I had to change out my upper blades and the first flight was horrible. I had already balanced the blade. I then checked the movement of the fly bar and upper blades and it seemed to be a bit hard. It turns out that one of the blade holes that slide on to the mount was very tight. I expanded the hole to make it better. Anyone else have this problem?
Old 07-25-2007 | 04:13 PM
Default RE: CX2 blade replacement
I have never had that problem, but I've heard of it often. Some guys ream the hole as a routine pre-assembly process. We also sand the link balls to get all of the flash from them so the link has NO drag. And check the width of the head compared to the width of the pair of blades when they are assembled. I have had the blades fit tight against the sides of the head (blue aluminum head). A little sandpaper fixed that also.
Soloboss
