E-Fllite BL setup question
FL
I would like to know from those that use the E-Flite recommended Bl motor and esc. if you experience these two things:
1. Does your motor have a little drag or resistance just after running? This goes away after a couple of minutes.
2. Does your esc have a steady (extra) beeps while you are programming it, even though the required beeps are there when they should be?
I would appreciate replies from those that use this setup.
orlbuzz
orlbuzz
