E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
4 in one problems???
Old 07-30-2007 | 09:08 AM
Default 4 in one problems???
My Blade CP was getting kinda slugish and weak and wouldn't fly for more than a few miutes. I realized it was the main motor going bad. I replaced the main motor with another stock 9 tooth motor but now the tail motor won't work. While troubleshooting this problem I switched the motor plugs in the 4 in one and the tail motor worked fine. Does this mean that my 4 in one has gone bad on one side? If so is there any way to fix it, or is replacement the only option?
At $70.00 bucks I might consider saving up and going brushless for the main and tail motors. Does anyone have a good setup that workes well on the CP? If so what parts do I need and where can I find them?
Holyhover/Scott
Old 07-30-2007 | 02:01 PM
noguy's Avatar
Default RE: 4 in one problems???
I think most people are using the eflite brushless setup for the main motor and a brushed tail with an ICS-50 esc.
my guess would be that this 4n1 is not of high enough quality to justify spending $70 on a new one.
You could also go a cheaper route with two brushed moors on separate gws esc's.
Old 07-31-2007 | 09:48 AM
How much time do you have on the tail motor? The BCP repacement tail motors are known for going bad in just a few hours and this can cause other problems, so you might want to try another tail motor on the proper 4 in 1 plug just for kicks. Another thing to check is the TM connector. Unplug the main motor and carefully "wiggle" the TM connector at the 4 in 1 and see if it runs. You can also try turning the gyro gain and proportional mix screws "up and down" a few times and then try the TM again.
Your tail motor may work OK while running off the 4 in 1 main motor plug (due to the higher output current that this plug provides)
and not at all while running off the 4 in 1 TM plug. I went through pretty much the same problems you describe and though that my 4 in 1 was bad (after replacing the main motor). It was, in reality, a bad relacement tail motor that I had installed a few weeks before. I found that the brushes in this TM were completely worn out at less then 3 hours of use. Just my .02 worth.
Good luck and good flying!
