E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
stripped servo?
Old 08-26-2007 | 05:44 PM
pilot143's Avatar
Default stripped servo?
I had my cx2 out the other day... after a small crash, one of the servos (roll) was out of alignment... didn't think much of it... brought it in... minor adjustment, and back outside for a flawless flight. but it happened again, and again even. the gears SEEM to be ok, but its obviously slipping. I wanted to swap the pitch with the roll servo, but that cant' happen as the holes on one side have to be removed to mount the roll servo.
I found replacement gears and servos from Horizon... but which do I need? again, the gears APPEAR to be fine... but it keeps happening. is it the motor or gears that are my issue?
thanks again...
