gyro
have a cp pro w/stock tail was whating to know if there is any way that i could link a non e-fight gyro with the stock tail have a brush less set up for the main and split the 6 ch 4in one or maybe it was a 3 in controller using it as a regaler 6 ch rx. can any one help me with this or is that it cant be done
your cp pro should have a receiver and a 3 in 1. Yes you can hook up any standard gyro, just use the instructions in the eflite manual, it's all gona be the same.
almost all heli's have a gyro, but some come with seperate gyro's and HH gyro's. Basically a HH gyro holds your tail in one spot, and a rate gyro dampens the movement of the tail. That's so that humans with slower reflexes than a gnat can actually fly the heli =)
check out this video for some more info
http://www.youtube.com/watch?v=_TLD8CqsN0M
yeah, the cp comes with the rate gyro. Most HH gyros can also be used as a rate gyro. basically a rate gyro will teach to to fly the tail and because of that reason impo is the way to learn , and the go to the HH tail for stunts if/when you get to that point =)
