Microheli aluminum main frame problems
Has anyone had any problems connecting the eflite S75 servos to the Microheli aluminum main frame. The servos mount using the screw holes on the top and bottom. Every time I go to mount the servos the cases break since the cases are brittle and to hard. Not immediately, but once I move the servos arms around and hook them up to the swash plate they start to crack. I am going to upgrade servos and would like to have a recommendation, any ideas? Any troubles with using alternate servos on a Blade CP pro?
I am starting to think that I should just leave the CP PRO alone and just buy a Trex 450 SE V2.
indeed - build a trex 450 sa, or if you like the blue alumibling, get a hdx450 from ushobbysupply - check out the hdx450 assy videos by finless for more info, great stuff
450 blades and everything are approx 3-4" longer than the cp's, and the tail rotor is belt drive so the tail handles better
edge
edge
ORIGINAL: afive6troll
What does MH recommend for servos in thier frame? Ya have me curious now!
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
