Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
 CX2 and FSOne connection >
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 01-01-2008 | 04:41 PM
Default CX2 and FSOne connection
I try to connect my LP5DSM transmitter which comes together with E-Flite CX2 with Hangar 9 flight simulator FS One.
When I connected JR cable (include in the FS One set) I just lost power on my transmitter. After thorough investigation I found that:
- LP5DSM trainer port has 4 pots. Counting from the bottom: +6v, signal, high, -6V.
- If you are plugging JR plug from FS One directly in trainer port it just shortening power.
Solutions for connection are the next:
First alternative:
To install additional female connector with 2 pots compatible with JR plug from FS One. To do that you must open LP5DSM transmitter box (unscrew 4 screws on the bottom of transmitter), connect "signal" to JR "lover" pot and "high" to "upper" pot. I put additional female connector next to CH5 knob on the transmitter. And it works fine after the routine transmitter calibration on FS One.
Second alternative:
To buy Trainer cord from Horizon Hobby Inc. (part number EFLH1059), cut it in the middle and to connect female JR the same way as in the first alternative. You will have nice cord which will be possible to use to connect any LP5DSM transmitter with FS One.
To enjoy the whole power of FS One for the simulation of CX2 flight you must purchase Hangar Pack 1 which includes Blade CX2 heli. It works great.
Good simulation with FS One.
Evaldas
Old 01-02-2008 | 07:44 AM
Default RE: CX2 and FSOne connection
Hi Eval...if all that doesn't work, try your TX with the
"free"" FMS program...all it takes for that is a stereo cable
and the FMS program and another program called Smart Pro Po..
good luck...John H.
Old 01-02-2008 | 04:27 PM
Thanks John,
Now it works fine. Where to get Smart Pro Po...?
Evaldas
