E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
CPPro Power Loss
Old 01-01-2008 | 09:15 PM
My Feedback: (18)
Default CPPro Power Loss
I just replaced the main stock motor and went out to fly. Seems to be low on power. I installed another new stock motor and nothing changed. I tried 3 fully charged packs on both motors with the same results....here's a bit about my setup:
Stock CPPro...never crashed or damaged
45 flights
Was low on power & run time before, changed main motor and fixed problem. This time changing motors did not help.
Everything else is the same as before, except the new motors.
Blades track and are balanced.
Temps when I tested were around 45 degrees and calm.
Any suggestions please???
Thanks and happy new year!!
Old 01-02-2008 | 12:14 AM
Default RE: CPPro Power Loss
you might need to check you batteries...you could have cell in them... check the amp with a volts meter
Old 01-02-2008 | 02:29 PM
My Feedback: (18)
All 3 batteries are good. I don't think that's the problem.
Amir
Old 01-02-2008 | 03:16 PM
you might want to check you bearings one might be locking up and slowing your head speed down
Old 01-03-2008 | 03:13 AM
My Feedback: (18)
That's a good idea. Thanks! I'll check it out.
Amir
Old 01-03-2008 | 01:48 PM
let me know how it goes..
