CX Motor Maintenance
Once again, I’m looking for the wisdom of the RCU forum community. Thanks to all who have replied to my previous posts. I have more questions:
I think one of my motors is sounding with a higher pitch than usual. Is this a bad thing?
Is there some type of maintenance I should perform on my stock motors?
Can I break them in even though my heli has had more than 40 flights? Or are they already “broken in” because of all the use and abuse?
Also, will a hot motor drain the battery quicker than a cool motor?
KS
There isn't much You can do on the stock motors except the following;
COMPLETE COOL DOWN AFTER EACH FLIGHT !
That, and that alone is pretty much the ONLY thing and the BEST thing You can do to ensure longevity.
Some people oil, I don't; but if You do; not more than 1/100th of a drop.
They are cheap; replace them, or upgrade to the XTREME'S, they are serviceable in the way of brush replacement, but You will smoke them too if they get too hot.
Gary
Gary
OH
Get a heat sink. I would run 4 battery packs back to back on my stock motors. I had about 200+ flights on them and the CX2 was used when I bought it before it died. I never did a cool down, just a heat sink. Good $3 to spend.
[8D]
