CX2 - Up'ing the POWER !
MI
The BCX2 w/stock Lipo is way under powered IMHO, switch to an 11.1v from a Blade Cp Pro or other, the difference is night and day, just remember to keep the fuses on your motors.
Don't worry about over heating the 3-N-1 the BCP Pro has the same 3-N-1 save for a few small pieces, but it will handle the heat. I've been running an 11.1 in my BCX2 and the only reason I fired my 3-N-1 is because I took my fuses off to get a full 8.4v to the motors, one of my motors burned out and subsequently fried the 3-N-1, which I repaired...
If you run a 3S, 11.1V pack, definitely watch the motor temp. If you get them too hot, you will cook the insulation off of the windings and severly degrade your brush life.
Hi guys, thankyou all for your recent feedback. BryFlyGuy, thankyou for your further Posts too, considering you also posted when I created this Thread a few months back! I think I will eat my words [)], and as you say BryFlyGuy, remove alot of the Aluminium upgrades, and revert back to the black plastic (apart from Swash?). [)]
See if this gives me a boost in vertical performance - only thing, wont my CX2 get blown around more being lighter outside??
Hopefully the shorter flybar/Xtreme motors and DN Power will help FIGHT the breezes!
Perhaps in a desperate act, I might think about sliding a 3S battery under there as a few have mentioned, but very wary I will kill my CX2 forever!? [&:]
Note, since my post the other day, the outer shaft is bent YET AGAIN (slight wobble there/vibration) -so perfect time to rebuild with the plastic items.
ORIGINAL: H3li
FWIW, I have two CX2's and both of them have all the aluminum bling. One of them also has the Xtreme folding blade grips. I have never tried to lift anything with them, but judging from the power I get, I can't see where I would have a problem with a FlyCamOne.
But... going back to plastic may be something you want to try. If you aren't happy with it that way, it's no big deal. You can tear a CX2 down and rebuildit from scratch in a couple of hours, so going back to aluminum will not be a big deal if that is what you decide. Plus, I think that it's a good idea to tear them apart and put them back together again periodically, anyway.
MD
h3li,
1st make sure both drive shafts and bearings are perfect. 2nd i would think about a 2.4 ghz spy cam running off the aux pwr on the reciver and use a ground reciver to record and see live video. most of these cams are tiny and have good video.
