"Blade 400" DX6i timer function not working
OK
Hello,
I hope I am not going crazy here. I haven't been able to get the timer function to work on my TX. I went into Setup>timer menu and I have the factory 4:30 timer set with the trainer function. But after pressing and releasing the trainer button for three seconds, the timer does nothing?
OK
I have tried that and the timer will not start? There is a function where you can set the timer to count up or down.
When the timer is set to count up and the trainer SW is activated for three seconds the timer goes to zero but never starts to count down?
Had my blade 400 3D for about 2 hours now.. any hints for getting the canopy on and off with the battery in place? Seems to take a long time.. maybe I'll get use to it, but seems difficult to hit those small gromet holes.
sc
sc
It's a royal pain in the rear at first. After messing with it a couple weeks, it gets a little easier... But it's still a royal pain in the rear! I use E-Flite 2100 mAh packs and it's even tighter than the stock 1800 mAh pack and sometimes it only takes a few seconds.... and other times I swear it'll never fit.
You'll just get used to it...
