Blade CX2 - Xtreme or AFCSystems 180 motor and battery questions
OK so I'm torn and confused about which motor to purchase as well as the best battery to be used with either motor for my CX2. I'd like to either go with:
AFC System 180 - Sold by BladeCX2.Com as the EXxTREME (AFC ) NEXT GENERATION motor
Xtreme 180 - Sold many places
Now which battery should I go with as well as which brand? Any other suggestions?
- 900mAH 10C
- 850mAH 15C
Thanks in advance.
- 900mAH 10C
- 850mAH 15C
Thanks in advance.
AB, CANADA
RE: Blade CX2 - Xtreme or AFCSystems 180 motor and battery questions
Well I have the Xtreme 180s and fly them with the DN Power 850mAh 15C's Great stuff. Really happy with the setup.
ORIGINAL: stump3r
Thanks!
AB, CANADA
ORIGINAL: puma1824
What is your average run/flight time with your setup? Do you have the silver brushes? Are you using the stock charger or other?
Thanks!
Thanks!
Still running the stock brushes. I have the silvers but the stockers haven't wore out yet.
The only problem I have had with the DN's is one of them goes out of balance from time to time.
Other than that good gear.
ORIGINAL: puma1824
- 900mAH 10C
- 850mAH 15C
Thanks in advance.
- 900mAH 10C
- 850mAH 15C
Thanks in advance.
I would go with a 15c+ battery
NE
This is also my first time seeing the AFC motors. But I like the Xtreme motors with silver brushes and 15C batteries.
I am still using the stock motors and haven't heard of the afc motors, but for puma8424, boomtown hobbies has the dn850 15c @3for55. I bought 3 of them, i don't see how you could get a much better battery for cx2. especially for that price. i am waiting for extreme 180S as i write this. also, the man who runs boomtown is very knowledgeable and willing to answer questions. i always call as I prefer talking to a person.
ORIGINAL: schreydog
So what's the "S" version have over the regular 180?
Thanks everyone for helping out. I decided on the Xtremes for two reasons;
1. Because the Xtreme 180 is a popular motor and I think I have better community support (at least for know while the AFCs are less known)
2. Boomtown had everything I wanted to purchase and could have shipped to me faster than the AFC (they're in Canada) BUT I do have to mention I'm completely satisfied with EXxtreme Core and blades I purchased from them.
Banned
Get the heat sinks for the 180s and make sure you have air flow. Check your brushes from time to time, when they wear out the helicopter will violently go into a full speed run where ever it wants to once the arm arcs on the copper armature. The three cell mod will be comming out shortly and will reduce heat, which is a problem out here in the desert. The X-treme 180s I have personally been very pleased with and will continue to run them. I have over heated a set and they lost their magnetizm so, once you run your motors through one battery, check to see if they are indeed overheating. With the heatsinks and making sure the sinks had airflow, no probs. Believe it or not, two cell runs create more heat than the three cell runs.
Banned
I have run both the stock and silver brushes, can't really say if I like one over the other exept, the stock last longer. I have been running three cell for months and get 20 minute flight times, but I have to be very careful about giving the craft power, it is an estes rocket ready to turn into a dot in the sky... lol.
NE
Is it cooler with the 3 cells because it doesn't need that much current for the same amount of work that the 2 cells do.
Banned
The way I understand it, higher voltage requires less amperage. It is the amperage going though the electrical circuit that causes the heat, also the resistance like when you slam the throttle on and the motors get all that power but have to pull those blades against the air to equil everything out. I am no expert but have seen all of this in action. I have also personally run a bunch of two cells, which I actually prefer do to it giving me a bit more control over the throttle. After I have been in the air for a while the three cells are a blast. There is one more thing that we are trying to figure out that is still bugging me, most of the time when I crash it is because of that damn nose drift. The three cell does aliviate this a bit due to it holding the voltage and amperage at a more constant rate. But it does not fix it entirely. I really would like that completely gone, then this thing would be pretty much perfect.
Banned
Ohh by the way.. DO NOT put a three cell on your stock helicopter, you will hurt the 4 in 1 controller. There is a modification that needs to be done. My pal is trying to figure out a way of telling everyone how to do this without messing up your system. It will happen, just give him time. He just refuses to put it out here, he got mad... lol.
